Originally posted by Divesplat
If, and its hard to tell here, only the throttle another possibility may be the linkage to the carb. Believe DA put longer carb arms and 3W still has to be extended.
The solder came loose on my extension and caused something similar as the arm would catch occasionally and speed up.
Just another possibility.
Ed
Thanks, Ed. That was the kind of experience I was wanting to hear so I could rule out everything. I checked out the linkage and the butterfly... all in working order. A new radio solved the problem.
