ORIGINAL: tool667
I recently installed the 15t pinion gear I do not seem to notice any difference at all? Any thoughts?
just that two tooth difference without anything else will be a difference, it will be slight, but still a difference. With the 15 tooth you'll notice a higher top speed. With the 13, you'll notice the truck is more responsive do to the increased low end. It won't be like "OMG I can't believe the low end" but it will be noticeable.
