RCU Forums - View Single Post - Servo recomendations for a 20lb Zero
Old 01-17-2013 | 06:35 AM
cswann821
Default Servo recomendations for a 20lb Zero
Hello,
I am getting ready to finish a CMP 80" 50cc gasser Japaneese Zero, whos kit has been sitting for about 3 years now. This is my first large scale bird and was wondering if someone could recommend some budget minded servos for the elev,ail,flaps,throttle,rudder ect. that will hold up well in this WB. The build threads on the WB say it well weigh a little over 20lbs once completed. I'd like to stick with Futaba since my radio and transmitter are...but if it will save me alot to switch brand servos thats fine.
Would pretty much anything that has metal gears and torque in the 65 and above range work?
I found these..
http://www3.towerhobbies.com/cgi-bin...XDWF8&P=ML
The Futaba S3305 w/ metal gears, has high tork and very affordable. Would these do the job?
<br type="_moz" />
