RCU Forums - View Single Post - NSRCA/AMA EXPO
Old 01-17-2013 | 03:17 PM
pvogel's Avatar
pvogel
Default RE: NSRCA/AMA EXPO
Hi Jim,
Yes, the files are human readable (though the format is dense) and you could modify the file on the computer and store the .jsn back on your SD card and it would pick up the model change immediately (it would probably be a bad idea to change the .jsn for the currently active model out from under the TX).
Jeti will also allow you to put more than one function on a switch.
Peter+
