Back at it....my desktop computer picked up something from all those job sites and ate its self so that was a full day a half gone fixing it....what a mess....
The hatches that came with the kit do not match anything and they are completly bare.....so out came the hl hatches I had from the doner tank...
cut the cover plate for the hinge....
I will add some texture and they will be done....next was the 75mm above the 128mm main gun....I am using the 75mm as my mount for the IR light so I wanted it to be well allined with the main gun.....I used a tube that the ir light and tube will fit into and glued it in so it would be well alined....
next on my hit list are the fender cranes for lifting those huge fenders up onto the tank after transport, I figured they would be carried on the tank as any track work would require the fenders to be pulled....I am also making pullies for them...
here is what they look like on the tank...
here is a drawing I found on wot as how they would have worked....mine are a little different....
