RCU Forums - View Single Post - Vstank King Tiger Problem
Old 01-17-2013 | 05:30 PM
B.A.D.A.S.S.Force's Avatar
B.A.D.A.S.S.Force
Default RE: Vstank King Tiger Problem
ORIGINAL: archelo
I will try to get some pictures today or tomorrow.
Both gears move freely. There are to motors inside the tank, one for the right side and one for the left. Each motor has a connector which independently connect to ports on the controller board inside the tank. Since I knew the left side moved forward properly, I simply swapped the left for the right and vice versa. I then powered up the tank and transmitter and pushed forward on the joystick. Suddenly, the right motor started working while connected to the left control port on the board. This at least confirmed that I dont have a bad motor. When I connected everything back like normal, the problem returned. Troubleshooting in this fashion tells me the that at least the motor isnt frozen or stuck and works properly. It also tells me that the problem must exist somewhere on the PCB. I will get some pics posted. Thanks again!
In an earlier post from the original thread where you first mentioned your tank, you also mentioned, "it has the push button controller", but now you say, "pushed forward on the joystick"?
This is confusing details. The push button controller has no joystick. So to clear things up, do you have the push button controller, or the joystick style controller?
Also, if the left motor was working normally before, & you hook the right motor to the left port & the motor itself is OK when tested, then it makes sense the motor isn't an issue. But this test doesn't tell you that the Tx is truly working properly or not.
So I'm not saying it isn't a tank PCB problem, because it certainly could be, but if you are having issues with just one side control, it can still be the Tx causing that issue with the way the contacts might be working, or in this case, might not working, or just a loose wire or plug in the Tx.
All you seemed to have ruled out is that both motors spin in both directions, & the gearbox seems to spin freely on both sides in both directions too, & since I haven't read anything you have done exclusively to test the Tx to rule it totally out as having no issues, I'm not sure why you still only want to focus entirely on the tank board as the only possible cause.
In my opinion, to do the full proper trouble shooting, I still suggest strongly that you take the Tx apart & check the internal plugs & connections, as well as that the contact pads are free from having any debris between them & the contact points on the board, & they are properly positioned where they should be. This is actually very easy to do, & at least an inspection might reveal something that is causing your issue. Even if everything inside looks OK too, at least that's one more trouble shooting step which really needed to be done, out of the way.
~ Craig ~
