ORIGINAL: daytonarc
ORIGINAL: Rodney
You want the widest layer first, not the narrower one. If you cover the layup with Saran Wrap (a type of kitchen plastic wrap) and smooth it out with your hand then let the epoxy cure overnight; when you remove the wrap you will have a perfectly smooth finish that will not require any sanding to smooth out any ridges.
Doesn't the epoxy stick to the plastic wrap?
I'd use waxed paper for effortless 'release'!
