RCU Forums - View Single Post - Vstank King Tiger Problem
Old 01-17-2013 | 06:02 PM
archelo
Default RE: Vstank King Tiger Problem
ORIGINAL: B.A.D.A.S.S.Force
ORIGINAL: archelo
Thats from a VStank ABRAMS that I also have which has the push button controller. This is the King Tiger with the VTX-10 .
Completely agree with your suggestion Craig. Im going to look at the Tx tonight and I hope that does it. Thanks so much for your responses!
OK, now we're getting somewhere. You know you could try switching the crystal inside the KT tank to the one from your inside your Abrams turret, then try using the push button controller on the KT to see if you get normal forward movement.
I'm also not sure the older push button controller will even work on a newer tank, since the mfu will be newer, & that is of course assuming your Abrams was still working OK using the push button controller.
~ Craig ~
Yes sir...tried that. The push button old controller doesnt work on the newer King. The ABRAMS and the King both have channel #2 crystalls. I have an extra #7 that I havent tried since I ran into this issue. Im going to go pull thsi thing apart now and see how much trouble I can get myself into...lol
