What about the (3) Rimfire's I have comming in the mail.
If I can get a summer on a plug I will be just fine. I guess I can allways switch later on. When you drill and tap the head for the 10mm threads to fit the CM6 do you have to have to run a spacer with the compression washer to obtain the correct spacing.
