RE: top flite p-51 giant scale
Sorry about the confusion, My Dle is mounted on the standoffs. Looking down on the engine/fuselage the carb is in the center of the of the fuselage and just infront of the firewall, maybe one inch space. The tank is centered on the inside of the fuselage preventing a strait pushrod run to the choke. I used a throttle extender on the throttle as the throttle arm was screwed on. I had planned on putting a ball link on the choke too. The choke arm is fixed on and I didn't really want to break the arm off if I didn't have to. I had thought about some sort of bell-crank system and mechanical push pull out the bottom by fire-wall.
Is your choke servo on the fire wall? I'm using a pitts style muffler designed for the Mustang.
Thanks for your reply
Art
