RE: RC Surfer
YPC
I have been thru motor changes (Feiago) was one. You Never Know.
My point is, The Compartment appears tight. If someone wants a board from you that
they will fit their own elecs, there has to be some space to allow different sized motors.
Looking at a recent pic, The Cooling line off the motor looks cramped from the servo ?
For the shaft set up, the 3.2 mm motor shaft is real weak, even with perfect alignment they have been proven to snap off
under a bit of load. A long 3.2 mm Drive shaft sounds problematic as swell. I tested Uni Joints years ago, and they didn't offer the results I was looking for.
But The R & D Is The Fun Part ...
