RE: Klass Kote Primer over Polycrylic?
Tony,
I don't know how much painting experence you have but if your spraying the primer, build it slowly. I usually dust the first coat on and let it flash for 20 minutes then a little heaver on the second and third coats with about 20 minutes between each coat. So far I have painted 6 planes with poly under both lacquer and expoxy. Where I see a problem with lifting is when someone tries to build a heavy fill coat on the first coat. And don't forget the flash time very important.. The attached plane was done with poly-lacquer-rustolem..
Rick
