RE: surface flutter
With large control surfaces and analog servos vibration itself can create the movement. Can you hold an aileron with the engine running and keep it from moving? Vibration with a glow engine is usually caused from an out of balance prop. Glitching usually shows up with just a couple control surfaces moving. With all of them moving it can be a bad RX glitching from a bad pot. Just some ideas to check out. Bypass the battery switch just by plugging the battery plug directly into any open port will tell you if it is a loose wire in the switch.
