ORIGINAL: nitrosportsandrunner
Right now, I think the XXX tires are the factor giving his truck the advantage. I know that CG plays a part. But the stock XXX tires are way better compond for the track than the torments (which are hard for long wear)
Not a chance.
If you could swap tires the XXX would still be able to run rings around the ECX.Putting Ferrari tires on a Prius, you've still got a Prius.
