RE: Traxxas Summit
I think the reason it looks pushed out on one side is just because of the diff lock sticking out, unless there's something else you're talking about that I can't see in the picture, the shafts on each side are slightly different lengths to compensate for the oddly shaped bulkheads. In any case the shaft shouldn't be rubbing the arm at all, I just checked and mine has plenty of clearance so there might be something maybe broken or bent in that area of the truck. Maybe take the shaft off for a closer look?
