RE: Hitec HS-635HB can you convert to non-carbonite servo?
You are correct .
I found it , just as you said
Note: Be aware that high vibration gas (not glow) engines combined with large control surfaces and large throws (3D models) can put undue strain on the gears. Metal geared servos are recommended for these applications even if under 12lbs.
Warning: Do not use thread lockers on Karbonite geared servo as it will cause the output shaft to fail.
Specifications:
Motor Type 3 Pole
Bearing Type Dual Ball bearing
Speed @ 60deg (4.8V/6.0V) 0.18/0.15
Torque oz/in (4.8V/6.0V) 69/83
Torque kg/cm (4.8/6.0V) 5.0/6.0
Size in Inches 1.56 x 0.77 x 1.52
Size in Millimeters 40 x 20 x 39
Weight 1.83ozs (51.9g)
Main Pages
Home
spacer
