RE: Hitec HS-635HB can you convert to non-carbonite servo?
It will bust a gear almost every time to!! I have the 5485"S Im not sure if you can use metal gears from any of the other 54XXX series servos or not!! I use 645 MG In most of my stuff. But I have 6 5485 digitals Im not using cause of this issue!! I have a 27% Edge 540 with a ZDZ 40cc in it and it busted one elevator at idle so No more of that!! It was on the ground when it happened. Lucky me.. But I would use them only as Hitech sais to! Just my 2C...
