ORIGINAL: nitrosportsandrunner
welcome to RCU
You are making a better start than most! Good purchases thus far.
And you pretty much have things right. You can charge at 1c, meaning 4amps for your 4000mah lipos. If you balance charge them, this will take alittle under 1 hour usually.
First of all thank you. I researched heavily before making the purchase so I hope the decision turns out to be good and it is actually as tough as people say it is.
Anyway, so if the battery charges in about 1 hour,
Does that means that i once I drain it after running the RC for about 15-20 minutes, I can immediately put it on charge for about an hour and then reuse it immediately !!!!?
That sounds to good to be true.. That's a very short charging time in my opinion.
<br type="_moz" />
