ORIGINAL: ejc34710
Correct me if i'm wrong, but he said the charger specs were .1-5.0 amp charge rate @ 1-6s lipo. That means it can very well charge a 6s lipo at 1c as long as the capacity is below 5000mah....
Seems you are right. ..I mixed up mAh rating with the no. Of cells. . Probably someone will second that. .
Cheers! .
<br type="_moz" />
