RE: 0.s.15 cv-rx refusing to keep running
Your engine's not running well because it's most likely not adjusted correctly. You'll need to check how the carburetor's set up. "Factory" settings are only starting points. You have to get the carburetor adjusted for your setup. You'll have to get the high-speed needle properly-adjusted and then get the idle mixture properly-adjusted.
