RCU Forums - View Single Post - STAB INCIDENCE
Old 01-22-2013 | 07:29 PM
kenh3497's Avatar
kenh3497
Default RE: STAB INCIDENCE
I'm in the process of building a Zlin 526. The wing is semi symmetrical at the root and is under-cambered at the tip. The stab is zero degrees and the wing is four degrees positive. The wing also has six degrees of washout. The engine is set a zero degrees of thrust. This is supposed to be exactly how the full scale is set up.
Ken
