RE: STAB INCIDENCE
Mike if I am getting this correct the engine thrust line is 0-0 as this is a turbined plane. Jim, the degrees quoted above are approximately the same as per original. The wing incidence angle is being taken as a parallel line to the centre line of the plane and is angled upwards from the trailing edge of the airfoil. I do not know if you can see it in the drawing.
Again thanks to all.
