RE: Sideways mounted srevos
Thanks! sounds like a plan, servos I've done were always verticle with horns exposed.
Attaching the controls to the horn, cables landed within the pocket between the ribs, may be a challenge though.
I may have to completely re-do the rod routing, I'll try and get pics tonight so you can better visualize thanks again,
Scratch building is sooo much fun lolo.
Ok I think just figured out a solution! Must I also install an access hatch on the bottom of the wing to connect the rods?
