ORIGINAL: Silent-AV8R
...I use APP on everything now. Keep in mind that the rating for the APP is 45 amps at 600 volts. So at 42 volts they can handle way more load than what we will ever see. .....
I might be reading that wrong but are you suggesting that APP can hande 45A @600 volts so they should be able to handle more current when used in a lower voltage system ie. 90A @300v or 450A at 60 volts??? If so I'm not sure that's quite how it works...
