RCU Forums - View Single Post - MODEL TECH SAPHIR
Old 01-23-2013 | 05:04 AM
Jon Wold's Avatar
Jon Wold
Default RE: MODEL TECH SAPHIR
ORIGINAL: doxilia
Jon,
It looks like you modified the hinge line to use center mounted hinges and a V-shape control LE. Were you able to do this simply by sanding the existing wood or did you have to add some?
David
Hi, I've not modified it. Elevator and wing are top hinged as it came out of the box, using Dubro std. pinned hinges. Works like a charm for me [8D]
