ORIGINAL: angus5
ORIGINAL: phmaximus
Humm I'm interested in that mod, please do post up,
U coud allways use that for a overdrive/counter steer drift setup too
Yes but that would require the rear to be a taller gear no? The probelm is I break the rear pinion 3 to 1 vs. the front one...
Yes, thats correct... but
if u were to countersteer it, it problary wouldent have that problem because of the reduced stress on the drive line from running drift wheels.
I think u have sold me on the idea, looks simple enough, simple swap over with some light cutting.
Hey how well does the shaft centre? ive noticed the Alloy shaft has alot of play in the stock pinion.
