RE: Winter Building Project
Because the Venture features top-grade wood that is cut out by a bandsaw, as opposed to mass-produced, ho-hum, die-crunched wood.
MinnFlyer has a point; while the Venture is aerobatic, it is a more of a majestic flyer than a throw-around model. By clipping the wing, you can make it pretty quick in roll; but that long empennage is just plain stable and forgiving. I guess the best way to describe it is that this model, when used with a buddy box, would be an excellent primary trainer. Did that with mine, as a matter of fact, a couple of times. Built per plans, and with minimum control throws, it is as docile and smooth a model as you can get; period.
So, if you're looking for something to get ignorant with, and are set on one of these two models, get the Four Star. Its wing has a more narrow chord; it has less fuselage area and tail area, and overall will be quicker.
Minnflyer,
I keep checking out that GP Extra. I assume it comes with your basic ABS (i.e., crap) cowl?
What about low-speed characterisitcs?
Steve
