RE: Caldera 3.0 questions?
Make sure your servo saver isn't adjusted too loose. If it is, your steering will be sluggish. Also, careful how big you go with tire size. The bigger they are the more low end you'll loose. You can compensate by changing your clutch bell. The less teeth on the bell, the greater the low end torque. Clutch bell from HPI Savage will fit.
