ORIGINAL: Dads like rc too
Make sure your servo saver isn't adjusted too loose. If it is, your steering will be sluggish. Also, careful how big you go with tire size. The bigger they are the more low end you'll loose. You can compensate by changing your clutch bell. The less teeth on the bell, the greater the low end torque. Clutch bell from HPI Savage will fit.
I didn't know I had a servo saver. Were and what does that look lie. still learning haha.
I was going to go with the same size tires as my buddies revo. That ok without changing out the clutch bell?
I am already peeling out everytime I take off. And I think the wider and taller tires will give me more stability and clearance.
