Chuck,
Ohe option would be to cut a thin sliver of a wedge to allow it to make the bend. It should not take much. If you are carefuyl, and use a wood (white) glue in the joint, it will sand without liaving a ridge and you'll never know you cut it. Compound curves can be a problem sometimes.
Are you a member of the Waco Brotherhood? Idon't see you mentioining it here. (Not that it makes a difference). If not all you need do is mention it and Bill will take care of that!
Joe
