RE: knife edge flight
ortho, consider that your elevator becomes your rudder (effectively) when the plane is rolled 90 degrees? Any trim you have on the elevator at that point will turn the plane? Thus, you want to trim the plane's CG for a neutral elevator....
The alternative to trimming the CG is to use your radio's rudder to elevator mixing capabilities?
