RCU Forums - View Single Post - Fox 3.2 and muffler problem
Old 09-15-2003 | 02:56 PM
GeraldRosebery
My Feedback: (14)
Default RE: Fox 3.2 and muffler problem
When you tap out the holes I recommend that you use the correct "numbered" drill for the tap you are using and use the correct high-speed steel "bottom tap" ( that is - not the pointed kind.) This is designed to tap dead-end holes. Use a lubricant when you tap aluminum and clean the hole regularly while doing it. Q-tips and solvent works well to remove the filings. You will be much happier with the result.
