Yeah, I've read about that. I actually went to two LHS in my area and none of them had the motor plate. Iguess Imay have to get it online.
ORIGINAL: mrbonez
one thing to keep in mind when changing the pinions on the smash is the motor mount plate . if you look at it you will notice you can NOT adjust the gear mesh as the motor mount plate has no slot cut as the mini t plate does no worries tho . just grab a motor plate from a losi mini t and it will bolt right up and your all set . also most of the mini t hop ups will fit your smash . the only thing i noticed to be different is the servo tie down. it is a separate piece on the mini t and on the smash the breast plate is all one piece with the servo tie down other then that its exactly the same as the mini t . sorry but i am terrible at explaining thing
