ORIGINAL: lenvanzanten
I bought a DL ignition for twins, to replace the DA. The module works just fine on any DL pickup switch, but refuses to work on the DA switch
Does anyone know the difference in the three wires between a Da pickup, and DL?
The readings on continuety seems to be reversed between white and red. I switched it but still no results.
Leonard
the DA uses a pick up coil instead of hall sensor like pretty much all the other ignitions. the lead to the coil has three wires but only two are actually hooked up to anything.
