Im not saying the TQi is better as i have no experiance with the Flysky
Fly Sky FS-iT4 4
Traxxas TQi
AFHDS
DSSS, RSSI, Cypress's WirelessUSB-LP
Servo Reversing
Servo Reversing
End Point Adjustment
Sub-trim Adjustment
Sub-trim Adjustment
Steering Exponential
Steering Speed Adjustment
Steering Mix Adjustment
Throttle Neutral (Dead Zone) Range Adjustment
Throttle Exponential Adjustment
Throttle Curve Adjustment
ABS Braking Programming
multiply profiles for each reciver
Throttle Speed Adjustment
Profile customization and sharing
Throttle Centering Position Programming
Built in fail safe
Throttle Idle Up Programming
Engine Cut Programming
Boat Mode
Brake Mixing
Full Channel Mixing
Servo Movement Display
Race Timer
mechanical and digital steering trim & customizable multi function knob
Key Programming
simple tree programing or touch key programming
20 Model Memory
30 Model Memory
Updates via USB
Updates via Wifi or 3g
5ms Frame rate (yet to be confirmed)
13ms frame rate
Not Compatable with older recivers
Compatiable with older TQ reviecers
Lipo pack with charging jack
AA batteries or nimh pack with charging jack
I can see the FS-iT4 4 does have some cool features
Lets compare durability
A ipod or iphone can be fitted with a Griffen survivor case thats rated to a 3 story fall.
and i know from experance that the TQi can easly take falls from 5 foot
only time will tell how the FS-iT4 4 will go from a 5 foot fall.
because the TQi is 3 seperate parts (controller, base & ipod/iphone) repair costs are cheaper. Ipod replacement screen & Digitizers are only $21 for a set
In terms of telemerty traxxas are years a head with there customizable gauges, scales, pictures, units, customizable dashboard, audiable alarms, average, low, max, current readings, option to record telemerty with audio, ability to expand to run additional sensors and even a real GPS
