ORIGINAL: Frank Schwartz
Yes. I would like very much to have a copy of the instructionos.
I, too, was told it would run either way, depending on the position of the points. I was also told that the fuel mixture was 2 to 1 SAE70 and Gasoline. and the needle valve was to be 5/8 of a turn open.... I haven't tried it yet....too cold outside to mess with it yet...
Frank
P.S. The 13/6 as recommended should work...but maybe a 14/6 for bettr flywheel effect might be better to start out with...
Frank,
Are you sure about 2:1 oil to gas? That makes it 67% oil which is awfully thick with oil. Maybe it was 20:1?
