RCU Forums - View Single Post - New to pattern competition question?
Old 01-27-2013 | 04:58 AM
cmoulder
Default RE: New to pattern competition question?
ORIGINAL: dahld
We probably need to define how we're using the word ''telemetry'', as it's being used in this thread to describe inert data (like RX voltage) that cannot effect the model's flight performance at all...
And...
It's also being used to describe ''...altitude, attitude, yaw or air speed where the transmitter could, on it's on, make corrections without input from the pilot...'' This type of information being fed back to the pilot from the model is already clearly out-lawed in the rules.
I don't yet own such a radio (yet), but I know others flying pattern that do. I don't know if the ''inert telemetry'' function (like RX voltage), can be disabled or not. If so, then CD's could just tell all contestants to disable the function if they want to fly at the contest. If not, and it's just part of the function of the TX and RX as they operate together, well, the issue needs to be thought through, or else we'll all be flying old ancient radios in a few years in order to be ''legal'' at events.
(-: Dave
If you're new to Pattern, this is the least of your worries. NOBODY is going to check or to complain until/unless you reach the upper echelons of Masters or FAI.
If you cheat, you cheat only yourself. If you don't keep track of and monitor your battery packs sufficiently on the ground so as to require in-flight feedback, you need to seriously take stock of your protocols and correct your deficiencies. Guys who fly electric Pattern regularly monitor their Rx packs by load-testing voltage and observing the IR's when recharging Rx and main packs. If there is any doubt about an Rx pack, it shouldn't be in the model in the first place.
