RCU Forums - View Single Post - DLE 55 spacers
Old 01-27-2013 | 03:41 PM
tande
My Feedback: (48)
Default RE: DLE 55 spacers
ORIGINAL: Planeclothes
I recently purchased a Peakmodel 50 size Edge 540 which I am presently putting together. I mounted a brand new DLE 55 using the stock standoffs and when I put the cowling in place found that the prop drive washer is more than 1/2'' BEHIND the cowling's center hole. On top of that I also observed the cowling looks off centered relative to the engine's center line. Obviously the firewall has some right/down thrust built in but the cowling's ring was not offset for that. Bottom line is I need to use 1/2'' (or slightly more) spacers and some washers behind the cowling ring to get better centering. I stopped by Home Depot today and picked up (4) 1/2'' long nylon spacers and (4) 5mm x 40mm bolts. I also purchased a 4 ft long 3/4'' hardwood dowel. This is my first project with an engine larger than 30cc and I am fully aware of how much more vibration a larger engine produces. My question is, would it be safe to use the nylon spacers (easy way out), or should I cut spacers out of hardwood?
If I understand you correctly, you will need a standoff distance of approx. 3-1/4" (stock "DLE" stand/offs I believe are 68mm plus your 1/2" or more).....seems like a lot to me.....I would contact "Blazing Star Mounts" ( [email protected] ) & have a talk with him about a CNC "Box" mount......FWIW
