NB the quote below is
NOT the BMFA test (no prizes for guessing where it comes from
Does anyone think that something like this would be better or worse, as a demonstration of competency to fly turbines?
Objective: The purpose of the flight test for the turbine applicant to demonstrate their skills, knowledge, and understanding of how to safely operate and fly a turbine model aircraft.
Key Elements: The following elements are to be demonstrated through action along with verbal discussion of the element were appropriate.
1. Demonstration of proper turbine ground operations
[ul][*]a. Discuss the need to keep the tailpipe area clear of people and flammable items during start, shutdown, and all ground operations.[*]b. Explain the response plan for dealing with an aircraft fire similar to one resulting from a hot start. Fire extinguisher to be present per BMFA safety regulations.[*]c. Explain the potential for a post crash fire and the response plan to deal with the situation. Explanation to include local fire department contact number and fire fighting equipment immediately available for the modeler to respond to the fire.[*]d. Explain and demonstrate typical turbine startup and shutdown procedures.
[/ul]
2. Flight Skills
[ul][*]a. Takeoff, to be held within 10 feet either direction of centerline, with smooth, controlled corrections as necessary.[*]b. Horizontal Figure 8. Pilot to hold altitude to within +/- 50 feet during the Figure 8. This demonstrates skills at both left and right hand patterns and the ability to control the models flight path.[*]c. Perform two aerobatic maneuvers with combined looping and rolling elements to be selected by the turbine applicant. Examples include Cuban 8, Humpty Bump with ½ roll, or similar maneuvers. This demonstrates the general flying skills of the modeler.[*]d. High Speed Circuit of the field performed at a safe high rate of speed. This demonstrates the ability to control a model aircraft at speed.[*]e. Square Traffic Pattern including a missed approach go-around. This maneuver to be in the opposite direction of the takeoff and landing if conditions allow. This demonstrates the ability to control a model aircraft in the landing approach mode.[*]f. Landing to a complete stop. Again, smooth, controlled corrections to the aircraft’s path after touchdown are required. The landing must be completed on the runway.[/ul]
