RE: Build thread BJ Craft Prolog V2 F3A Unlimited version
What are you reccomending for a "properly specified wing incidence"? I assume using the nose ring for the thrust line and the stab is pre-set but the wing incidence is not finalized as received. Should you just glue in the pins or is there some adjustment to be made which you consider would work better?
John
