RCU Forums - View Single Post - Rebuilding the Super Cub
Old 01-29-2013 | 01:03 AM
Boostedrexx
Default Rebuilding the Super Cub
Ok so After lookin around at other planes to pick up I decided to just rebuild my super cub.Ok so servos,esc/rx,motor where toasted after a water crash.I replaced the motor with the stock cub motor.Instead of buying the stock rx/esc combo for 50 I decided to pick up a 20a esc and hooked it up to my futaba rx.I replaced the servo's with factory ones aswell.All I have left to buy are batteries.Now the stock battery is a 11.1 V 3s 1300mah battery.I was looking on hobbyking and found the same one in spec made turnigy but for way cheaper which is expected.After scrolling down a bit I found this battery
https://www.hobbyking.com/hobbyking/...Lipo_Pack.html
Now the difference is the mah is more which means longer flight time and so is the discharge.Now I know the esc can handle that but can the factory brushed motor handle the increased discharge??
also any other ideas welcomed<br type="_moz" />
