RE: trust the thrust line?
Are you just trying to figure out how far over to move the engine so it is centered to the cowl when you re-mount the engine?? If so I can just show you in a couple photos. Dose the plane call for right thrust in the instructions? If so and there is no built in thrust on the fire wall then you do need to make a shim.
