RE: Sideways mounted srevos
I have the srevos set up in the wing like all your photos depict, I did use 4 servos 2 aileron and 2 flaps so all the clumsy belcranks are eliminated. i have run into another snag with the flaps, my gold fg series futaba does not have end point adjustments on ch's 6-7, I'm having trouble because for the servo arm to portrude out of the wing slot it has to be quite long which results in double the travel I need, a small servo wheel puts the control way low below the slot? Any work around ideas would be appreciated thanks.
