RCU Forums - View Single Post - Which glue
Thread: Which glue
Old 01-29-2013 | 09:28 PM
j.duncker's Avatar
j.duncker
Default RE: Which glue
Toothpicks work well as dowels in 3/16th 1/4 size stringers.
I would use 30 min epoxy.
Apply a very thin coat rubbed in well on the gluing areas use a hair dryer or some other heat source to help the epoxy penetrate the wood, scrape off any excess.
Allow to cure for 30 mins to an hour MAX.
Apply a more epoxy and make the joint with clamps if possible. Again scrape off any excess.
When I am building I make every effort to keep the tail of a model as light as possible. Excess weight there requires a disproportional amount of nose weight to get the CG in the right place. One 0z at tail will need about 8 oz lead in the nose to compensate. Light models fly better.
