RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 01-30-2013 | 02:11 PM
  #6385
Ernie Misner's Avatar
Ernie Misner
Default RE: DLE 20cc Gasser! (Data & Links 1st Post)
First, it sounds like you need to change your throttle geometry or tx curve so that 1/2 travel on the stick gives you less rpm's. If it is deadsticking after half throttle it might be too lean on the HSN, have a filter, or fuel delivery problem.
ORIGINAL: [email protected]
on my gas engine when i have the throttle stick on the transmitter 1/2 open the engine is running full throttle >> if i push the stick further the engine dies out>>>>any one might know why> thank you
