RCU Forums - View Single Post - joining wing center section
Old 01-30-2013 | 02:12 PM
Rodney
Default RE: joining wing center section
I do both, heat gun and then wrap with Saran wrap as that lets you feather out the edges much neater as you can use your fingers to smooth out any edges under the wrap and the result is much slicker (smoother) than if you do not use the Saran Wrap.
