RCU Forums - View Single Post - WARNING AVOID NITRO PLANES!
Old 01-30-2013 | 08:04 PM
  #101
GallopingGhostler's Avatar
GallopingGhostler
Default RE: WARNING AVOID NITRO PLANES!
ORIGINAL: rednekk58 Learn how to build n repair. You'll always crash. I bring a garbage bag with me flying. When I crash I put it all in the bag, n spread it out at home to see if I can fix it. AFTER th emotions are subsided. If the foam is not smashed into lil pieces it's easy to repair. Maybe this place can help with a new wing. https://www.flyingfoam.com/ Good luck!
There's a lot of merit in what you say and with your methodology. It is amazing in crash rebuilding how that with the smaller fragments, one can piece together wing ribs, bulkheads, longerons, etc. and salvage a lot of work up front. From the other pieces unsuitable for reusing, after piecing together, one can use them as patterns for cutting out new parts or reinforce them through a variety of methods. So it is worthwhile to pick up all crash damage parts as much as possible. More often than not a wreck can be rebuilt successfully, and with less trouble than building a whole new kit.
The old scratch build masters such as Walt Musciano and the late Keith Laumer used to have chapters in their books on techniques they used to rebuild wrecks.
