RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 01-30-2013 | 10:05 PM
  #6392
bcchi
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
ORIGINAL: ahicks
ORIGINAL: bcchi
ORIGINAL: ahicks
Mesaflyer,
No intent to argue here. Really. Sorry for coming off that way? I'm agreeing with what you're saying, but possibly confusing the discussion with more information regarding a different problem with very similar symptoms.
Mody,
Try to get it dialed in. Start over with your tuning if you need to? If that idle hang/lack of reliable idle speed thing becomes a big deal for you, put a module on it to make things much simpler. Don't worry about the timing thing. You can come back to that later once you've got a little confidence/familiarity built up? What's going on there not very likely going to cause the engine to die on you or cause you other issues. It's a fine tune kind of thing?
Stop reading this forum until you get some stick time on that plane!
You can tune till the cows come home but the DL20 will run like crap untill you change the ignition.That is if you have the no# 4 Ign.All you have to do is look at it with a timing light and the problem is very easy to see.
BCCHI
With all due respect, there are way too many of us having too much fun with the engine the way it was shipped for me to agree with a blanket statement like the one you're making. Can it be improved on? Sure, and in that light, I'll agree with you.
Telling somebody that the engine they've been having a blast with is actually running like crap, and the only way to make it right is to replace the module, may be seen as questionable advice? Telling somebody that's struggling trying to get their engine running that the module will ''fix'' it not much better....
If you can't make it run to your satisfaction replace the module. That should simplify things for you. Is a new module a requirement? No, not hardly.
OK fine with me. I no many fliers are running the #4 Ign and get along fine.The new RCEXL ignition is a complete new circuit and is good.Any one that is rated for the higher voltage should be OK.
Youll never no how little I really care.The main thing to remember is this is a hobby have fun.
BCCHI
BC.
