RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 01-31-2013 | 09:25 PM
  #6399
bcchi
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
ORIGINAL: Ernie Misner
Please tell us about your timing light. Is it the automotive type that simply runs from the spark plug cap, through the light, and then to the spark plug? I thought the shielded type plug wire we use kept a timing light from working somehow. Hey, if a timing light works that easily, a person could mount a degree wheel right between the prop and the hub, and take a look at your timing while it's running instead of static, by hand.
I posted about my timing light but do n ot see it. I use a light from a company called Flaming River part noFR 1001.Uses two D-cells for power.Made a short jumper from short piece of plug wire spark plug terminal and top off a spark plug.You have to use a ground wire from plug cap to engine.
BCCHI
