ORIGINAL: bcchi
ORIGINAL: Ernie Misner
Please tell us about your timing light. Is it the automotive type that simply runs from the spark plug cap, through the light, and then to the spark plug? I thought the shielded type plug wire we use kept a timing light from working somehow. Hey, if a timing light works that easily, a person could mount a degree wheel right between the prop and the hub, and take a look at your timing while it's running instead of static, by hand.
I posted about my timing light but do n ot see it. I use a light from a company called Flaming River part noFR 1001.Uses two D-cells for power.Made a short jumper from short piece of plug wire spark plug terminal and top off a spark plug.You have to use a ground wire from plug cap to engine.
BCCHI
Sorry about the double post I am brain dead tonight,or all the time I guess.Will be flying the XYZ 20 from Valley View as sone as it warms up a little.Had it apart and looks good.Come with Walbro carb. CM-6 spark plug and new high voltage RCEXL ignition.Good timing.OhOh voided my warranty took engine apart.
FOG
